Re: CA18DET machining
There is someone who used a ca20 bottom end, ca18 main ladder brace with mitsu rods, ca20 crank, 6800rpm redline with ca18det top end was doing lap times as fast as his sr20det upgrade. He limited it to 6800rpm using stock ca20 cast crank but apparantely had more midrange than the sr20.
The ca20 block is taller so with longer rods and ca18de crank you can have very good rod stroke ratio. Have to upgrade all to ca18det but use longer conrods. The better rod stroke ratio, less side loading and bigger capacity should equate to a strong engine. Full counterweighed spool crank would help they come in ca18 or 20 strokes but if using a the ca20 stroke in a ca18 block I think you better get very shoort comp height pistons and longer rods than what spool supply as the rods stroke ratio is still not great in that combo.
Posted on: 2011/7/19 11:38
From radelaide
cheers guys thanks for ur help
Posted on: 2011/7/19 10:19
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
From Brisbane
put this site in your favorites
www.spoolimports.com
Spool CA18 Stroker Kit (rods,piston,crank) is only $2490
piston and rods $1140
must have tho... cams+springs dont go anything over 260 duration or it will #OOPS# you power band
Posted on: 2011/7/19 9:29
From Sydney, Australia
I'm with pigdog.
As my engine builder said. .. want more power?, get forgies, a bigger turbo and run more boost.
Get new camshafts and a ported head to suit if you can afford it.
The big dollar engines in magazines are not the sort of thing that belongs in a budget build.
Do everything in moderation. Don't get obsessed about the car rebuild.
Posted on: 2011/7/19 7:26
From radelaide
ok lol
Posted on: 2011/7/19 5:21
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
From Geelong, Vic
or you could just do a basic bottom end rebuild and add forged pistons. then just have lots of boost and a good tune
pretty sure the ca20 bottom end is weaker than the ca18 one, so it would probably be a step backwards to use it
Posted on: 2011/7/19 4:00
CA18DET machining
From radelaide
hey guys just wondering wat would be a good way to head to pull power from the ca with out going over the top im thinking i might buy a ca20 bottom as i can machining pulleys and that up at work. wat u think guys
im pretty keen coz this gonna be a long build
cheers dave
Posted on: 2011/7/19 3:12
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
