Re: wheel width
love those words there:
"i havent gone low enough for that to happen yet"
was good to see your rig on the cruise- took me a whole to notice was a long bed. now get a chrome grille on there and dump it
Posted on: 2011/8/23 13:13
Re: wheel width
From Cheltenham
i have got 13 x 8 with +3 offset but i have also got 185/65 tires stretched on and they sit about 20mm out of the guard but dont rub as i havent gone low enough for that to happen yet
also if you want to try and work it out a bit better you can use this website first as it gives the changes in how far out the rim will poke and how much diff the inset will be as well to the current wheel details
www.willtheyfit.com
Posted on: 2011/8/23 12:09
Re: wheel width
From Albury
I have got 215 x 13's all round on 6" minilite copies.
Tight fit on back but no issues. Just depends on wheel offset you get
Cheers
Bob
Posted on: 2011/8/22 8:29
Re: wheel width
From NSW, Australia
Yea im the same as Shoota, i have 15inch skyline chasers and cant fit bigger than 205's. But it all depends on the rims and off set.
Posted on: 2011/8/22 4:28
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: wheel width
From Melbourne, Australia
I have never actually measured them. I'll check it tomorrow. They're perfect for the rear. Now that I have coilovers another 10mm negative offset would be even better for the front.
Posted on: 2011/8/20 13:42
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Re: wheel width
Not too shy to talk
From Cronulla Nsw
hey shoota what offset you running?
Posted on: 2011/8/20 9:26
ca18det 1200 ute in build.
Re: wheel width
I don't think you will get any bigger than 205's under the rear without mods. My 17x7's are 4mm fromm the leaves and if I lowered it they would be only a few mm inside the lip of the rear guard. By rolling and slightly stretching the guards you might get a 215mm in. Unfortunately it comes down to trial and error. Get a 7" wide rim and see what tyre you can get on it. You can legally go 25mm over rim width but go even bigger if it'll fit.
Posted on: 2011/8/19 12:52
Current Fleet-
Re: wheel width
From Goulburn NSW
Im pretty shore that the leaf spring run parralel to the chassie.I byte ute has 225s ive talked to 44lex and he said to check out i byte ute as i said it has 225s but u will have to do the gaurds.
Posted on: 2011/8/19 8:54
Re: wheel width
Not too shy to talk
From Cronulla Nsw
yeh i saw his build, but he has gone 4 link. really wanting to see what can fit with leaves. appreciate it though mcdat
Posted on: 2011/8/19 8:49
Re: wheel width
From Goulburn NSW
Hi B_tsolakis check out rsr100 project build he has managed to get 235s under his but its a bloody tight fit, but possible.I think that most people go 205.
Posted on: 2011/8/19 8:45
