Re: R31 diff on a Datsun 120Y
From Melbourne,Australia
Ive got a r31 diff in mine took a bit of work to get in there but let me know if you want pics or info
Posted on: 2012/1/23 21:21
Could go h165 with bluebird disks and a topgear LSD
Posted on: 2012/1/23 12:16
Car free
Ute diff is drum rear stock. You can mod to fit r31 rear disk brakes.
Posted on: 2012/1/23 11:26
Phantom grip is a mod done to the diff center not the brakes. It's a spring loaded pack that "locks" the diff under load. It's considered the poor mans LSD now. At $450 I don't consider cheap but is compared to other lsds, but uf you get h165, topgear on here may habe done lsds left from his run of them.
Posted on: 2012/1/23 11:25
From Adelaide South Australia
and it has LSD with disks?
Posted on: 2012/1/23 11:16
Bolts in but tail shaft might need shortening only bout $100 to 200. Always try get the tail shaft with diff.
does the h165 just bolt right on or more shortening?
Posted on: 2012/1/23 11:09
thanks for your help mate
Posted on: 2012/1/23 11:07
Yes bw 78 is r31 diff. You can fit disks to h150 etc. you won't need bw78 with a series, hell its overkill in my l series hence why bw68. $450 for phantom grip later on.
Posted on: 2012/1/23 11:02
Yes bw78 is r31 diff! But for mild worked a series motor bw78 will be too big, they weigh as much as a a series motor! Lol better off with a phantom grip and finding either a h165 or bw68 in my opinion
Car free
