Re: what temp should a ca run????
Those are Nissan part numbers. But they are not rare, all the usual aftermarket companies make them too.
Posted on: 2012/2/22 3:35
From brisbane
hey ddgonzal
are they part numbers from nissan or just a regular part number
Posted on: 2012/2/22 2:55
A15 1200 ute, 77 mini -b16a honda vtec project
For USA CA18DE, they have 180, 190 and 195. Hot thermostats are favored here for the heater, it gets very cold in many areas so they need a hot room heater.
Posted on: 2012/2/22 0:01
Nissan thermostats for 180SX:
* 21200-V0201 82C/180F
* 21200-V0206 OPTION 88C/190F
same as E15/E16, CA18DE/CA20S, Z22/Z20, L24E, Nissan, Subaru, Isuzu
Posted on: 2012/2/21 23:48
My l series did similar, runs cooler on freeway but in traffic will get around 88-90deg c
But LPG runs hotter too
Posted on: 2012/2/21 23:39
From brisbane
its about 195 200 max in trafficw on highway or driving round is about 180-185. last time repco only had a listing for a 195 thermostat. is there another one that will fit for a180 temp?????
Posted on: 2012/2/21 23:32
From Malaysia
what happens if i overcool the oil?
Posted on: 2012/2/21 23:31
That's normal. 192 was optional for Datsun 1200.
You can fit a 180 to keep the oil optimum temp. You dont' want to cool the oil too much, so if you fit an external cooler make sure it has thermostatic control.
Posted on: 2012/2/21 22:44
From Melbourne, Australia
if thats farenheit thats fine
that equals 90 degrees
sounds quite hot for a normal running temp, but if it doesnt get much higher thats fine, if it was going up to 95 degrees plus i would definitely be worried
sounds like you need to buy a cooler thermostat really though, then your motors normal temp will be a bit cooler, which allows for a bit of heat build up sitting and traffic lights and stuff
Posted on: 2012/2/21 21:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From brisbane
my ca is running at about 195 an and was wondering if thats normal. i vaugely remember trying to buy a thermostat for my old ca a few years back and i think all i could get was a 195???? thermos kick i around ghen too... is this ok ok.
Posted on: 2012/2/21 21:04
