Re: WTB standard 1200 strut springs to suit an L series conversion
king springs list KDFL-17 as standard height for a 1200/120y and lowered height for a stanza..... KDFL-57 are lowered for a 1200/120y.
interesting. but the kdfl-17 indicates similar spring rates are required.
personally id get slightly stiffer even though its only 10kg over the front axle.
i went way stiffer and have 250lb spings now... 225 would be better. and i have l16 in there too.
Posted on: 2012/7/5 15:31
From Armidale N.S.W
We used H/D 120y king springs for L16 conversion and used two upper strut cup things welded together. Firstly on the lower one we machined/filed off the lip that the bearing sits on and made the hole bigger.So it slipped over the insert easily. Mainly cause the springs weren't captive enough for our liking when jacked up under engine crossmember.
Posted on: 2012/7/5 10:35
73 1200 wagon SOLD
Just use king spring HD ones. They list same number for both cars
Posted on: 2012/7/5 10:33
Not too shy to talk
From Melbourne, Australia
Hi,
Just looking for some heavy duty springs to suit an L seires conversion, for a standard 1200 strut.
Thanks
Posted on: 2012/7/5 10:23
