Re: Starting help.
From south australia
Sounds like the starter. Check all the wires are on correctly and the motors earth is still good if not id pull the starter off and try on the ground it may just be a bit sticky and needs a good clean and grease. Or its just plain stuffed.
Posted on: 2012/8/21 9:58
The meaning of life is not in the fridge..
Its in the shed....
Starting help.
Hi everyone. Just wanting to use your diagnostic skill although I bet it's something dead simple. Ute has always been a start first time every time job. It was driven to and loaded on the truck in Darwin 2 weeks ago. It has now arrived in Vic and won't crank over at all, not even with a starter/jumper pack, just clicks.
Battery is 6 months old, terminals are clean, etc. push start and she fires up pretty easy and drives fine.
Rooted starter motor? Other suggestions?
Posted on: 2012/8/21 9:49
