Re: problems with 4spd
Not too shy to talk
couldnt tell you i took it into a mechanic to get the conversion done as i rarely get spare time between work. i will keep these things in mind when i get a chance to work on my car thanks for your help mate
cheers
Posted on: 2012/9/16 11:19
From Wanneroo, Western Australia
So the clutch is new, huh? Hmmm...
Was the face of the pressure plate cleaned before it was fitted? It's been a while since I was on the tools, but from memory the pressure plate face is greased by the manufacturer to prevent corrosion. If it wasn't cleaned, it would have contaminated the clutch plate. You can try getting the contaminants out by dousing it with methylated spirits and setting it alight (the heat shiuld draw the contaminates out), but it's not guaranteed to get it all out and should be done under VERY controlled circumstances!
Also, was the flywheel machined beforehand? What about the rear main oil seal? Unless the seal was replaced (or is sealing well), you might as well replace it while you're there.
Good luck today and remember to keep the prop shaft in the back of the 'box!
Posted on: 2012/9/16 0:58
Not too shy to talk
oh ok well i got a brand new clutch put in about two months ago when i got the engine conversion done, i had it converter to manual at the same time. also its only been drivin three times since the conversion. ile pull it apart tomoro anyway atleast now i know its likely to be the clutch thanks for all your help guys appreciate it bigtime :)
Posted on: 2012/9/15 13:26
Must be clutch plate. Time to get a new one, methinks.
Posted on: 2012/9/15 11:27
Not too shy to talk
weve jacked it up got the wheels moving but when its back on the ground it will only move slightly in 1st and reverse the driveshaft was barely turning
Posted on: 2012/9/15 9:25
From Trinidad and tobago
I had Same problems a while back.1200 was in the body shop for a month When time to move no gear selecting,Jacked up the back and tried to accelerate no spining of the wheels.
Turned out notting happed to the box we had to take it down.
When we took it out the clutch disc was stuck to the flywheel due to moisture in the garage.
We sanded the disc a bit then put it back together,everything worked fine afterthat.
Hope this helped,Cheers Darren
Posted on: 2012/9/14 16:33
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From vic
does the pedal have any resistance could be brocken cable inside but you would know if it did.
Posted on: 2012/9/14 9:15
Not too shy to talk
Thanks for the feedback guys i really appreciate it. ive tried moving the car in 1st 2nd and reverse it wont budge.
hi tom thanks for the advice hopefully tomoro ile get it off the ground and give that ago cheers
Posted on: 2012/9/14 8:56
From vic
have you tried moving the car in 2nd gear? maybe isn't engaging 1st.
Posted on: 2012/9/14 7:06
From Las Vegas USA
Start by getting the car up on jack stands, so you can see what is going on.
First step is the clutch disengaging?.....does the clutch fork move back when you depress the clutch................I actually had one stick on a Volvo rally car..........thought the clutch was gone but it wasn't............bunch of dirt packed up the bell housing.
Next step put it in gear while the car is off the ground...............if the wheels spin it's the clutch is likely done, with no load you can gently accelerate to see if the wheels spin a little faster..........no need to go faster than 10 mph on the speedo.
Then work back through the drive train but if somrthin in the tranny or rear end were broken it would likely make nasty noises.
Also make sure the car really is in gear, with the car off the ground and the motor off you work the wheels back and forth then try put it in gear.
Tom
Posted on: 2012/9/14 4:57
