Re: FS Brake upgrade/calipers
From Ballarat Victoria
I`m only selling the fronts. Its basicly a rebuilt set of R32 4 piston calipers and some ally hats to mount some wilwood rotors to. Some good pads included. The rotors that will be going with it are probably unserviceable.
The new owner will have to make a mount on their struts for the calipers and probably buy some new discs.
If someone just wants the calipers with the bendix ultimates, i`ll sell them for $250.
Posted on: 2012/10/9 14:16
VIC DYNO HIRE
am half tempted to try adapt this setup to my thousand, just not sure how the front would go
Posted on: 2012/10/9 11:16
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Yes, they fit under 13`s. Im now using 15`s and are going to take these off to go to larger rotors and calipers.
Posted on: 2012/10/9 11:09
VIC DYNO HIRE
is this the setup that fit under 13's?
Posted on: 2012/10/9 10:32
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
They are on 180b struts currently. The ally hats bolt onto the four bolt at the back of the standard 180b hub. Im not sure if the bolt patern is the same on other datto hubs.
This is a pic before i had the hats anodised.
Posted on: 2012/10/9 10:15
VIC DYNO HIRE
what strut will these fit? ie. stanza, std 1200 etc?
Posted on: 2012/10/9 10:09
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Im selling the brakes off the race coupe. 265mm Willwood rotors, Gold anodised ally hats, R32 Skyline calipers(new kit recently fitted), 2 sets of pads(EBC`s, Ultimates).
Discs need machining or replacing.
$450.
A caliper bracket will have to be fabicated for the struts. I think i still have a template that i could supply aswell.
Posted on: 2012/10/9 10:02
Edited by sikyne on 2012/10/9 10:26:12
VIC DYNO HIRE
