Re: diff to suit ?
From Snohomish, WA USA
I welded the spider gears on my H150 which I got out of my B210. My A15 toasted it. I picked up an H165 and welded the spider gears again. My A15 toasted that one as well. I now have a welded H190 out of a 320 pickup. The only mod. I did was move the leaf spring mounts out about 2 inches. This one wont break even with the Z motor I currently have in it.
Posted on: 2012/10/14 6:35
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: diff to suit ?
Not too shy to talk
From Western Sydney
Thanks alot for the piece of advice given b310gx. My 1200 is 81 model, ill have a look at the diff tomorrow and post up. I'm not looking for a diff to handle crazy hp as it is only a daily and not needed but would like to upgrade to a better diff..
Posted on: 2012/10/13 10:47
Re: diff to suit ?
From sydney australia
It all depends what year your ute was made in, whether it has a H145 or H165 diff centre. The easiest way I know of is the H145's ususlly have studs on the diff housing, holding the centre in, while the H165's have bolts doing this job. If you've got the H145, it'll take a fair amount of punishment, except if you weld the spider gears up, when it'll break both axles at the spline ends the first time you seriously drop the clutch. The H165 will take anything an A series engine can dish out, because the more horsepower it makes, the less immediate torque it'll have. I've had H165's behind 1600cc A15's & they weren't a problem.
If you want to go any bigger, the main problem is that things have to be cut down to suit, like axles & housings & such, which gets expensive, particularly if it's not necessary. Alternatives could be an R31 borg warner diff or maybe a Ford 8 inch diff, or the diff from a 520/620 ute. Hope this helps you find out what you've got & if it's good enough for what you want.
Posted on: 2012/10/13 9:13
Re: diff to suit ?
From Perth WA AUS
I stuffed up a gear change but still:
http://www.youtube.com/watch?v=nQRCL1BhvQQ&feature=g-all-u
EDIT claimed 160hp at the flywheel not the wheels, oneday I will get it back on the dyno and see what it really does at the wheels.
Posted on: 2012/10/12 13:02
Edited by levey on 2012/10/13 8:00:25
Datsun 1200 2Dr sedan.
Re: diff to suit ?
From Just out of Melbourne Aust
a H165 with 4.11's has put up with 140hp at the wheels from my race spec L20B, complete with R spec tyres and burnouts at hillclimbs, leave it in there until it breaks!
Posted on: 2012/10/12 11:57
Re: diff to suit ?
Sounds sick! Got any vids? 160hp would be damn nice im assuming its running twins or fuel injection?
Posted on: 2012/10/12 10:50
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: diff to suit ?
From Perth WA AUS
I don't really have any specific details Ed, Sidedraught had the engine built so best to ask him.
All I know is 1608cc, built by Stewart Wilkins I think and head by Jeff Taylor.
Motor was built for 160hp.
Hope this helps, Levey.
Posted on: 2012/10/12 10:42
Re: diff to suit ?
What ^
Levey can i ask your engine mods? Im thinking of doing a mild streeter a15, what did u bore it to in order to get 1608??
Cheers
Ed
Posted on: 2012/10/12 10:35
1200 Ute - Mild A12
Re: diff to suit ?
Wish could same could be said after dropping your guts
Posted on: 2012/10/12 10:23
Re: diff to suit ?
From Perth WA AUS
In my car I have an A15 with a bit of work done to it (1608cc)and I am using a H145 stock diff with H145 4.11 alloy centre. Just avoid dropping the clutch and it will last quite well.
Posted on: 2012/10/12 10:21
