Re: Inhibit switch wiring question??
From San Diego,California
Thanks very much.
Posted on: 2012/11/22 5:00
Mahalo Victor
Are you talking about wires at the 6-pin connector? I'd the leave that alone unless you want to run new wires all the way down to the transmission. I'd connect the nuetral start wires together at the end.
The two green wires are for the kickdown switch, which is in the automatic. No longer needed.
Posted on: 2012/11/22 4:00
Along with the 2 BY and 2 RB there are 2 green wires ..I thought those green wires were the reverse switch?
Posted on: 2012/11/22 3:36
Mahalo Victor
oh that's right you converting from Automatic to manual.
Depends on the year.
There is a 6-terminal connector on the firewall just above the rocker cover.
Leave this connected as the other wires are needed.
Down by the tranmission where the harness ends. The starter wires are BY (black with Yellow stripe) or BR (black with Red stripe.
* Connect the two BY or BR wires together. This is for the starter
* Plug the two RB or R wires into the manual transmission Reverse Lamp switch
Posted on: 2012/11/21 22:13
Well it sat's to bridge the wires ....I'm guessing it won't start If I don't do that? Not sure ?
My goal is to start the car when I'm ready, I'm about a week and a half from Ignition !
Trying to get things in order so I'm not scrambling around last minute .
A lot of my now how is coming from the wiki...My fist 1200.
Posted on: 2012/11/21 22:03
Mahalo Victor
It doesn't say because few have an Automatic 1200, and even fewer have tried to bypass the switch.
What is your goal?
Posted on: 2012/11/21 4:05
The Inhibit switch witch wire's do you bridge there are 2 red and 2 black...2 red together or the 2 black or he red to the black??
The wiki doesn't say?
Posted on: 2012/11/21 3:53
Mahalo Victor
