Re: ute disc brake conversion
No, not over the top. Many guys here think the Sunny brakes are not "enough". Should work fine.
Posted on: 2013/4/9 7:57
From Mordialloc Victoria 3195
Thanks for the reply . I know the coupe would be the best way to go but threr harder to come by and i've got acess to a sunny as well as its brake master and booster - bit over the top ?
Cheers D
Posted on: 2013/4/9 7:33
Yes, sure it has been done. Sunny brakes are larger than 1200 brakes too.
The stub-axle assembly is the strut, it is of one piece with the strut housing. Fit the 1200 spring to the sunny strut and bolt the whole thing in. Use a 1200 disc-brake master cylinder and brake lines. See B310 Strut Swap.
Or easier yet, bolt in the whole strut/brake assembly from a 1200 coupe.
Posted on: 2013/4/9 1:35
can anyone tell me if the front disc brake stub axle assembly off a datsun sunny
is an easy option for retro-fitting to a datto ute or are they too different.
Cheers David
Posted on: 2013/4/8 22:34
