Re: Various Stuff for sale/free
From Canberra
All the stuff is either on Hold or has been Sold.
Will keep you posted if anything falls through.
Cheers
Bryan
Posted on: 2013/9/10 6:37
From rutherford
pm'd you
Posted on: 2013/9/10 4:15
From Canberra
Time to clean out the garage. Located in Newcastle.
I have a few boxes of stuff to go (Either someone gets it or it goes to the tip).
Free if you want to take the lot (Pick up only, bit of a lucky dip).
What's in the boxes, mostly off a Coupe (some CA18DET stuff).
Rear ashtrays, sun visors, pedal box x2, coupe side vents (External), headlights, dash vents, Dash insert (Round face), coupe rear shocks, steering parts, R31 struts (Spring perch cut off for coilover), stainless mandral bends, blowoff valve, Coupe wire harness, CA wire harness (mostly all there), CA18DET block(disassembled), CA intake manifold Inc throttle body, central locking kit, Big yellow flares, two guards (Seen better days), 1200 bonnet with vents (seen better days), two coupe doors (RH +LH - heavily dinted but not rusty), Coupe fuel tank modified for external EFI pump pickup and return line, Sedan (or Wagon) fuel tank. Heater Box complete. Radiator with thermo fans (three core custom made to suit CA in a 1200).
What I'd like to sell:
$350
Unfinished Coilover setup. Shortened Stanza struts (200b length I think) with Maddat coilover threaded sleeves, Pedders gas shocks, coilover springs (200lbs), spare 250lbs springs, R31 calipers (Spare pair of calipers) on 260mm disc, Fit under 14s (setup done less then 1000kms), lucas Brake pads. One hub modified to suit.
What needs to be done, On Hub is not right, you will need a new hub machined to suit the good one. New bearings will be required plus bolts to put it all together, cheap setup when you consider coilover sleeves are $250 a pair.
$100
Sandblasted and lip polished TRX rims x4 with a set of wheel nuts to suit (With tyres). Pick up only.
Drop me a PM if your interested.
Bryan
TRX Wheels
Strut setup
Various stuff
Posted on: 2013/9/8 7:11
