Re: Wtb:120y steering knuckles and 1200 door cards (qld)
Not too shy to talk
From Queensland
Oh ok thanks, it's just where you bolt it to the bottom of the strut, one bolt goes in and the other one is a few mm out, and it looks like the strut should take a larger knuckle, the one I have seems small? Ill try post a pic tonight, thanks for the info tho :)
Posted on: 2013/9/25 0:43
Steering Arm
early 120Y same as 1200 sedan/coupe/wagon
late 120Y same as 1976-up 1200 ute
or you could use 1200 LCA with 1200 knuckle arm + 120Y struts.
Posted on: 2013/9/24 17:11
Not too shy to talk
From Queensland
G'day folks, I brought some 120y struts (upgrade to disc brakes) and the steering knuckle is different to the standard 1200 drum setup I had, anyway I'm after both sides so I can put the disc brakes in and get rego :)
Also I would like some door cards (standard if possible)
Thanks guys :)
Located Logan area will travel for parts - Tom 0450 889 600
Posted on: 2013/9/24 9:12
