Re: problems fitting 120y discs to 1200 ute
Possible causes include
* LCA are modified. They are normally same length as early ute LCA
* Struts are not 120Y
* spindles or strut housings are bent
* You haven't rolled the ute back and forth after changing the suspension
Posted on: 2015/5/11 12:25
Hi all, just finished fitting 120y struts with gas inserts and discs to my ute. The problem is that the wheels now have a lot of camber, the top of the wheel is about 20 -30mm further out than the bottom. I fitted lower control arms and cross member from a 78 ute. The left hand side seems worse than the right. Does anyone have any ideas of what I have done wrong. Thanks.
Posted on: 2015/5/11 10:28
