Re: wanted Datsun 1600 sump and pikup
From sydney australia
I've definitely got the right hand sump, but it has an oil return pipe & a dip stick fitted to it. You might be able to find something close to yourself through the Nissan Datsun club of SA. I'd search engine them.
Posted on: 2016/1/3 8:33
From Adelaide, Australia
I recon the steering linkage is there. Prob why I need a mid sump
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
The Datsun 510 (1600) uses a mid-sump pan, so if that's what you needed ... a rear sump pan probably won't work. You can look under your 620 and see if a rear sump pan fits. Sometimes the steering linkage is right there
Posted on: 2016/1/3 5:44
They are quite different. The rear sump models like the 1600 & the 180B have the engine crossmember under the front of the motor, so the deep part of the sump is to the rear. With the front sump cars like the Stanza (A10),200B (810)& Bluebird (910)have the crossmember go under the back of the motor, so the deep part of the sump goes to the front. Will try & find the sump to measure it.
Posted on: 2016/1/3 1:17
Its to go in a 620 Ute. Was told I needed a 1600 one. Is there much difference?
Posted on: 2016/1/2 10:35
Do you want front or rear sump? I have a rear sump L18 sump & pick up that I swapped over for a Stanza sump & pick up. Should be close enough to work. I'll try & find it & get a weight.
Posted on: 2016/1/1 23:21
I know this is a 1200 forum but thought I'd try my luck. Just chasing a Datsun 1600 sump and pickup. If ubhave one to sell can u pm me with price and postage to 5113 south Australia. Thanks
Posted on: 2016/1/1 13:01
