Re: Sr20 Vet
From Mackay
Posted on: 2016/2/14 5:41
Edited by Wogboy on 2016/2/14 9:02:02
Edited by Wogboy on 2016/2/14 9:07:20
Edited by Wogboy on 2016/2/14 9:08:38
Edited by Wogboy on 2016/2/14 9:09:24
Built not bought
Re: Sr20 Vet
From Mackay
Cheers ddgonzal I'll give it a go 👍👍
Yea as for the bullet I've been bitten by the Hp bug many years ago
My supra currently makes 903 rwhp
Fg falcon ute 608 rwhp
Datto at the moment not sure but went 13.5 down the 1/4
Posted on: 2016/2/14 5:32
Built not bought
Re: Sr20 Vet
Sounds like your build will be a bullet
For uploading photos, make sure they are 1280 px or less before uploading. You can use the free app "Resize Me" or something similar on your iPad
Posted on: 2016/2/14 4:41
Re: Sr20 Vet
From Mackay
Sorry guys been a while since I've posted a pic on here. Just tried to upload some images off my iPad but not having much luck :(
Posted on: 2016/2/14 4:29
Built not bought
Re: Sr20 Vet
From Mackay
As for power I'm hoping to make atleast 500 rwhp upto 700 rwhp 👍👍
Here's a pic of the current combo that I'm running
Posted on: 2016/2/14 4:25
Built not bought
Re: Sr20 Vet
From Mackay
I've previously converted a 4agte and w55 box into it but want to go a bit further with the ute
So far I have for the build
Sr20 det block
Sr 20 vet head
Mazworks head and main studs
Plazmaman girdle
Taarks solenoid relocation kit and cas kit
Mazworks plenum
Built c4 auto
Hks t51r Spl bb
Just need to decide on rods and pistons and assemble the motor, also work out what size converter will work with the combo
Posted on: 2016/2/14 4:21
Built not bought
Re: Sr20 Vet
For the X member I'll modify my spare one but do the Sr guys just use the stock mounts on the motor ? To adapt to the Maddat X member
Yes, you can modify the 1200 crossmember just like for L-series but put the holes a little forward, See L/Z/KA/SR Crossmember. Many here use 510 style (low profile) rubber insulators, the SR20 insulators are better but thicker. Escort style puck insulators are a good heavy duty choice for off-roading
Or you can use the Maddat SR20 crossmember. Most guys use generic puck-style insulators with that Maddat unit
Posted on: 2016/2/14 2:50
Re: Sr20 Vet
SR20VET is from the X-Trail GT all-wheel-drive. What most guys do is get a Silvia SR20DET and swap the VET head
KA24DE is fine and make 156HP. A long long way from 280 hp of the SR20VET let alone the naturally aspirated SR16VE's 175 hp. Nissan VVL is the key feature
Posted on: 2016/2/14 2:42
Re: Sr20 Vet
Dont forget the overlooked cheaper, easier to play with KA24DE head
On a 2.1 Z22 bottom end and L20B crank and H beam rods and
factory 89mm pistons. Z22 blocks take 89-90mm bore with ease
Posted on: 2016/2/14 2:01
Re: Sr20 Vet
From Mackay
Thanks for the info ddgonzal 👍👍
For the fire wall I'll mostlikely move the whole section behind the motor back about 40mm to clear the taarks solenoid relocation kit (20mm thick ) compared to the vvl solenoids 115mm and will look a lot tidier in the long run and makes fun r easy install and removal of the motor so that I'm not damaging the paint etc
Also have purchased a Ross balancer and will remove the front pulley as it won't be needed to give me a extra 20-30mm at the front
Posted on: 2016/2/14 1:50
Built not bought
