Re: ca18det swap
From Kyabram vic, aust,
after laying on my head all day I have finally got the clutch pedal and master cyl in and Im happy with it
It lines up perfect.
I found a 180b cylinder that is has a 5/8 bore
and it fitted well
Posted on: 2003/1/19 14:00
Re: ca18det swap
From Brisbane, Australia
the hydraulic clutch conversion is simply a matter of using the complete clutch pedal assembly and master cylinder that comes with your front cut. if you don't have a front cut you can buy them from importers for about $30.
rowlz
Posted on: 2003/1/19 13:44
Re: ca18det swap
From Mudgee NSW Australia
I used to run a holley red it was very noisy too when i upgraded to the porshe EFI pump I also upgraded to a carter black 110gall per hour its a lot quieter and dosnt run out of puff keeping the surge tank full I dont use a brake booster I find a nice hard pedal better. A lot better feel when racing
Posted on: 2003/1/19 6:15
Re: ca18det swap
Hey datto_dave,
I probably should have mentioned that Steve is also in Brisbane, and his race car is a 1200 coupe with CA18DET. He uses a remote clutch master mounted under dash I think. He can probably help source the motor too.
Posted on: 2003/1/17 1:54
Re: ca18det swap
From Sydney, Australia
other than the rooted oil ring in my car the rest of the setup i have is awesome andrew deniss did the conversion for me he did an awesome job on my car hes a great resource for this type of conversion and any other one to a datto so if u need any help regarding this conversion on a 1200 ask andrew hes the best!! (sorry andrew LOL)
Posted on: 2003/1/16 13:03
Re: ca18det swap
Thanx Andrew,
origionally I was running a 120y booster but I found after fitting it there was not much difference in breaking.
There is also no room for the clutch master cyl and its getting pritty cluttered in that area as it is,inlet manifold, brakes, clutch starter and a bit of wireing all in the same area.
One other question while Im going, what suggestions would you have for a fuel pump to get to the surg tank I have fitted a holley blue but its way too noisy, Ive tryed to insulate it but I dont like it any ideas??
I believe you run a red, are they any quieter?
Posted on: 2003/1/16 12:33
Re: ca18det swap
The hydrualic clutch conversion is a major pain in the ass Ive done it three times now first in the 13B Jport 1200 ute with supra5 speed :) then in my Ca18det 1200 coupe and last again a ca18 conversion for micheal into his 1200 coupe. Best bet is to pull you brake master cylinder off and drill a hole beside it pretty close the same size so bot the clutch and brake master cylinder can be done up and not hit each other then the hard part of modifying the pedal so the rod ataches to teh piedal and pushes at the right angle. (pain in the ass) under the dash I take the seats ect out so you can lie under there with a lead ligth and sort of see what your doing.
Cheers Andrew
IF YOUR NOT DRIFTING YOUR NOT GOING FAST ENOUGH
Posted on: 2003/1/16 12:02
Re: ca18det swap
I bought my ca18det complete with all the needed hang on bits plus it came with a ca bell housing for $1100, and it is garanteed to be a good runner.
He was aware that I was going to put an after market computer in it.
He also was very helpfull.
I got mine from
. Central Vic Auto Parts 7980 GV Highway Kialla(Shepparton),
Vic 3631 Telephone 03 5823 1911
Great mob!!
I also got my cross member from MAD DAT motorsport, it cost $350, wasnt cheep but it is a bolt in thing and comes powder coated
The only other hurdle I have had to over come is the trans tunnel, the manual gearbox I am running is a 240k box and although it fitted in the manual trans tunnel it was very tight, so I have just finished cutting out the manual tunnel and fitted an auto tunnel.
Tonight I fitted the engine back in and there is heaps of room around the gearbox now its great.
The next thing I have to tackel is the clutch
I have been looking and there is not much space to fit the master cyl.
Has any one else had this problem?? and how did they over come it??
Posted on: 2003/1/16 11:20
Re: ca18det swap
From Western Sydney
mikali wrote:
just a word of warning when youre sourcing a motor make sure u check it from top to bottom dont just pick up a pack and expect it to be in great nick like they tell u i just got one and the rings are gone and supposedly its my fault coz i put an mt8 on it ...theres all sorts of things that can void a warranty so be careful.... oh also if anyone wants to know where i bought the motor from in sydney so u dont get ripped off pm me id be glad to tell you :D
Better still, buy a cheap engine, making sure you get all the parts you need and then rebuild it, most engines now are over 100,000k's and are due for a freshen up. Import engines are too much of a lucky dip to just throw straight in i reckon.
Posted on: 2003/1/16 9:43
www.datnet.org
Re: ca18det swap
datto_dave, you could email Steve about the conversion sdraheim@ozemail.com.au He's the current Qld Improved Production Champ for over 3000cc with one of these engines, and certainly has all the knowledge and skills to help you out.
There are a few really good suspension specialists in Brisbane, I'd recommend Fulcrum at Moorooka 3892 9000. Ask for Darren and tell him that Harry sent you. He has been very helpful with my 1200 coupe and some others I know of.
Posted on: 2003/1/16 7:04
