Browsing this Thread:
1 Anonymous Users
Re: Brake Booster |
From Melbourne, Australia
nah no diffrence auto to manual, the sunny vooster and 180b master is a good combo with my brakes which is four wheel discs, with anything less than 4 wheel discs youd have to have pretty skinny legs to need a booster i reckon
Posted on: 2003/6/5 13:20
Re: Brake Booster |
From Christchurch, New Zealand
I may be wrong, but if I remember correctly Hillman Hunters had a factory remotely mounted booster.
When I got my coupe it had a booster mounted on the passenger strut tower (RHD). It was all a bit untidy so I ripped it out and binned it, my understanding is that if everything is correctly sized you don't need a booster anyway.
Out of interest is there any difference between the manual and auto brake components?
Posted on: 2003/6/5 13:13
Re: Brake Booster |
From Warwick, QLD
From talking to dattodude (Chris) he said the lancer booster fits with the CA, which is my plans. As for clutch master, nissan vans I'm unsure on the actual model yet to find out. Have in cabin clutch masters, because the 180B clutch master tends to hit the intake plenum. Where as the van's ones are in the cabin, so no hitting issues.
A simple braket is needed to be made up to fit the van's clutch master it hooks up to the steering wheel column support. The resiviour can be modded so you can fill it in he engine bay and not the cabin.
Cheers Damo
PS When I get my clutch master hooked up I'll take pics of it and put it in the tech section
Posted on: 2003/6/5 12:46
Drive It Like You Stole It Every Car Has 500hp In The Wet Team NEW SKOOL
Re: Brake Booster |
From Melbourne AUS
dattodude does the lancer booster/master cylinder setup fit with the CA conversion?
also what clutch setup are you using?
Posted on: 2003/6/5 11:31
1973 B110 A12
Re: Brake Booster |
From sydney australia
the us equivalent model might be the dodge colt,of about late 70's early 80's,rear wheel drive.i saw a photo of one in a don garlits book once,after it had been rear-ended by a drunk driver,& that car was sold in australia as a galant.they were made by mitsubishi,which was owned by chrysler at the time.it has an adaptor for a two stud at the fire wall to 4 stud at the booster.hope this points you in the right direction.
Posted on: 2003/6/5 11:26
Re: Brake Booster |
From Sydney, Australia
Hi Matt,
You need to convert your car to RHD ..That'll solve that problem. I'm not aware of a US equivalent. I think the American 70s/80s obsession with big V8s might have not made the US market a good place for the Lancer. So I don't know if there's an equivalent. Can't find any internet photos.
Chris.
Posted on: 2003/6/5 6:25
Re: Brake Booster |
From California
Quote: I don't like to sound like a broken record, but I always recommend the Mitsubishi/Chrysler LA/LB Lancer Booster and Master cylinder. Get the splitter valve too. Works nicely. You can get them for AU$50-60 complete from the wreckers. Uh, what would be the U.S. equivalent model/year? (not that a booster will work on a LHD 1200 anyway).
Posted on: 2003/6/5 6:01
Re: Brake Booster |
If you are already running front discs/rear drums, then it will work. I cannot vouch for 4wheel drums. If you can't lock up your brakes underload, then the booster will help. But as we all agree. with the boost, comes loss of feel. So normally the booster is only required with the addition of bigger front discs.
Chris
Posted on: 2003/6/5 5:37
Re: Brake Booster |
From Portland, Vic
With this setup, would you just remove your standard brake resovior and bolt up the new booster and included res?
How much better would the brakes be with a brake booster? Will the pedal feel be different?
Sorry to bring up an old thread, but I was thinking about adding one to my ute depeding on ease of fitment versus actual gains.
Thanks,
Leigh
Posted on: 2003/6/5 3:50
- 1985 Datsun 1200 Ute - S5 13b Turbo
Re: Brake Booster |
Chris
Posted on: 2003/6/2 7:02
