Re: valve springs
From sydney australia
you could try vw beetle springs,from the flat 4,i've used these in an a15,& cost me about $40 dollars oz.be sure to get real ones,as there are some fake ones ie not spring steel, floating around here in oz.
Posted on: 2003/7/10 10:45
valve springs
From Christchurch New Zealand
does anyone know of a cheap straight swap for the valve springs as i am building a turbo motor and the old springs a F**ked not compression force left in them
Posted on: 2003/7/9 9:33
"If your not living on the edge your taking up too much space" Rod Millen
