Re: valve springs
From Okinawa, Japan
Contact Feral.... that's where I got mine.
Posted on: 2003/11/19 23:02
Re: valve springs
From Canberra, Australia
Team_Dat wrote:
so where do i get these springs from.
Yeah, where from?
please.
Posted on: 2003/11/19 14:33
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: valve springs
2332, you nailed it in one.
Posted on: 2003/11/19 8:55
Re: valve springs
what he said...
Posted on: 2003/11/19 7:38
Re: valve springs
From Perth W.A
Posted on: 2003/11/19 0:38
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: valve springs
From Okinawa, Japan
Double valve springs prevent high rpm oscillations that can occur at a certain frequency (or rpm) with a certain spring rate. Since the inner and outer springs have different rates, they will counteract the oscillations.
Posted on: 2003/11/18 14:18
Re: valve springs
From durban, south africa
they reduce valve bounce, allowing you to rev higher!
Posted on: 2003/11/18 14:16
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: valve springs
A thread resurection!
Ummm same thing with me.
Just some simple questions:
Double valve springs will do what?
Where would I buy said double valve springs from?
Are they easy to fit?
Posted on: 2003/11/18 14:12
Re: valve springs
From Millgrove Vic OZ
These are special A series springs and do not suit anything else. You could also use A series GX springs , they may be easier to get?
L series springs dont fit.
Posted on: 2003/10/3 23:08
Cheers Feral
Re: valve springs
can you please tell me what car i can get them off.
thanks
nic
Posted on: 2003/10/3 12:49
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
