heads
From Midway City, California
will the A12 head fit onto the A15
i have the oval port head but i want the round head one
Posted on: 2007/10/24 5:36
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
heads
From Freo
yes they are interchangeable, but the inlet manifold will need to be changed to suit..
Posted on: 2007/10/24 5:43
A15 PSI Project Motor
'72 CB750k,
Re: heads
elaborate as i am stupid
Posted on: 2007/10/24 5:44
Re: heads
From Mie Japan
As for the cylinder head, the bolt distance is the same.
The installation is possible to A10 - A15.
But I am different from an inlet port in stats.
Posted on: 2007/10/24 7:41
Re: heads
What dundee means is that your inlet manifold on the current A15 head (oval port) will have to be changed to suit the round port head- so round port manifold with round port head, and oval port manifold for oval port head.......hmm
Posted on: 2007/10/24 14:27
Re: heads
Not too shy to talk
From Barbados
Why do you want the the A12 round port head on the 1500? I thought the oval port A15 head was supposed to be better.
Posted on: 2007/10/24 15:02
Re: heads
Thats kinda what I've been thinking, the oval port head is superior considering airflow?
Posted on: 2007/10/24 15:24
Re: heads
From Burbank, CA
I have a round port A15 head, I had thought it would have more low end torque, and a bit less topend, counting on going turbo, the smaller ports would be made up for in boost.
Posted on: 2007/10/24 15:31
|||\ 81 KPB310 /|||
Re: heads
From NZ
Can't see any upside in replacing oval port with round.
Posted on: 2007/10/26 8:52
Re: heads
Quite a regular
From TOWNSVILLE QLD
it probly wouldnt be worth it becuase you'd loose top end to make more bottem end but u'd loose a lot of top end for a small amout of gain in low rev range. but than this done with a turbo im unsure of what the result would be
Posted on: 2007/10/27 3:20
