s13 struts
From hobart tas
just wondering if anyone has tried modifiing s13 struts to suit 1200 as i need s13 wheel offset instead of the standard 1200
Posted on: 2008/10/25 11:07
Re: s13 struts
From Tamworth , NSW
use the search function on the left.you will find tonnes of info.
this has been covered a bazillion times.
Posted on: 2008/10/25 11:09
Re: s13 struts
From hobart tas
cheers
Posted on: 2008/10/25 11:17
Re: s13 struts
From Brisvegas, oz
yep ive got them, what did you wanna know
Posted on: 2008/10/25 12:23
www.camerasplus.com.au
Re: s13 struts
what threaded sleaves and collars are thise frank? look very similar to what pigdog and i are running
Posted on: 2008/10/25 13:17
Re: s13 struts
From Brisvegas, oz
alll i know is they are kyb inserts and king springs built by kev rowley, im not much of a fan for the blue on them
Posted on: 2008/10/25 22:30
Re: s13 struts
From malta
so u r using the kyb agx series??????????
how do u describe the road holding in turns???
Posted on: 2008/10/27 7:28
Re: s13 struts
From Brisvegas, oz
couldnt say what the road hanling is yet as its on the project
Posted on: 2008/10/27 7:35
Re: s13 struts
From hobart tas
are you using s13 control arms ball joint front hub etc, want to run s13 offset to open up my variety on wheels
Posted on: 2008/10/27 9:03
Re: s13 struts
From Brisvegas, oz
yeah i use the s13 strut, s13 hub and knuckle, the s13 lower control arm and the r31 radius rods.... not only does it open up wheel range it also allows brake upgrades aswell. you could even run the s14 lcas ,s14 hubs and knuckles on the s13 struts which will give you 5 stud aswell
Posted on: 2008/10/27 9:15
(1) 2 3 4 5 »
