Dellorto Carburetor DHLA , Idle slowly increses?
From Canada, B.C , Richmond
Hi everyone, just got the gearbox swapped out in the 1000 and reinstalled the carb. However, the car now starts idle at about 900rpm, then slowly goes up to 1500 by itself. I've adjusted the idle screw all the way up and it's still gaining RPMS.
Any idea what's going on?
gif  dhlaadjustment2.gif (56.55 KB)
5610_4b832ac4be8ed.gif 500X443 px
Posted on: 2010/2/23 1:09
Re: Dellorto Carburetor DHLA , Idle slowly increses?
From Freo
the cable is too tight?
Posted on: 2010/2/23 1:45
A15 PSI Project Motor
'72 CB750k,
From Atlanta, Georgia
Check your choke. I had a similar problem with my carb idling at 1500-2000. Turns out my choke wasn't operating correctly. Had to make a minor adjustment that the previous owner didn't know to do, and now all is well.
Posted on: 2010/2/23 1:54
1981 Datsun B310
1973 Honda CB175 K7 Cafe
From Ringwood, Melbourne, AUS
Choke or maybe float level/float needle valve sealing?
Posted on: 2010/2/23 10:51
From Newcastle nsw
check for a air leak. use carb cleaner or start ya bastard and spray around where carb joins manifold. if the engine changes note or revs, youve got a leak somewhere
Posted on: 2010/2/24 8:43
From Toowoomba, Qld
heres a silly one, do you have a return spring on the accelerator cable?
Cheers
Dave.
Posted on: 2010/2/24 9:08
