Browsing this Thread:
1 Anonymous Users
Building an A15.. Suggestions? |
From Atlanta, Georgia
I'm in the process of building up my A15 in my Sunny, and I need to know some opinions on this. I'm working off a low budget, so any advice on how to save money would be appreciated. The plan is to build a decent amount of N/A horsepower.
-So far, I've killed all the emissions and installed a new MSD Blaster 3 coil on my electronic dizzy. I got a 32/36 Weber DGAV to install as well as plans on the drawing board for a custom header based off my stock exhaust manifold and glasspack to finish it off.
-As far as valve train, what should I look for? I'm planning on pulling the head this summer and rebuilding the head, lapping the valves, new valve seals, etc. Should I consider stronger valve springs as well? Or are the stock one's okay on an N/A engine? I don't really plan on revving beyond 6500
-What are your opinion's on re-ground cams over new cams? I know I can save a ton of money by having a cam reground instead of buying a new cam.
-I need to try and avoid pulling the engine. I have too many problems as is with the county code enforcement, and I can't risk any violation's. Pulling the engine would draw a little too much attention.
Sorry about all the questions, I'm kind of a noob when it comes down to A-series and I don't want to kill anything.
Posted on: 2010/5/4 4:21
1981 Datsun B310 1973 Honda CB175 K7 Cafe
Re: Building an A15.. Suggestions? |
From Invercargill, New Zealand
You're not going to see much of an increase in hp with the mods you have described but you will end up with a very usable street motor. Strong accurate spark - you have done. Refresh the head as you have planned - don't worry about stronger valve springs as the factory springs are fine for 6500. Re-ground cam will be fine.
Not sure if you have plans to tidy up the bottom end but I would try and do that if you want a 0 hour motor with no weak spots.
Posted on: 2010/5/4 6:33
From Melbourne, Oz
Id go a 4-2-1 extractor aswell. with the right cam grind and the weber and good spark you should have a very tourqey a series that will drive verry nicely.
Posted on: 2010/5/4 6:48
"I hav achieved wood"
Well, I don't really plan on seeing a ton of HP out of this, I just want, as you said, a more streetable motor. The bottom end isn't going to end up with a lot of attention. Just new rod bearings and such. A bottom end job isn't easy to do with the block in the car. Not around here anyways. It's got 200K+ miles, so it will see it soon whether I do it now or not.
The 4-2-1 was my original thought. I was going to cut the stock mani and build off of it, or just try and find another one to screw with. I like lots of torque ;)
Posted on: 2010/5/5 0:58
Also, would it be worth building up an A15? Or do you guys think it would be more logical to get an L series to fit in? There's a nice L20B in a scrap yard around here that I've had my eye's on.
Posted on: 2010/5/5 2:35
From mandurah
id go L series for power ,but i like the A series motors better and they are what 1200s should have but i wouldnt mind a mild L20 !!
Posted on: 2010/5/5 10:01
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From Sydney
if i were you i would save more $$$$ and go ca18det carnt go wrong there champ or a 200hp 13b rotary
Posted on: 2010/5/5 10:54
Well, I'm fighting between 3 possibilities here.
1. Build my A15 a little tougher and spend the rest of my money on suspension. 2. Spend a little time rebuilding the L-series and drop it in one dark night when noones watching 3. Pull the rotary from the '82 RX7 sitting a the junkyard that I got the dash out of for my Sunny.
If I had the money for a Cadet or SRDET, I'd go that rout for SURE! Thats future plans. lol
Posted on: 2010/5/5 19:55
From Sydney
well depending on where you live rotrys are not legit in datsun 1200s but its heaps cheaper than most conversions if its weber but injected n ecu can get expensive.. just bridge port your 13b and leave it carbureted n you will be pulling 180kw no probs..
Posted on: 2010/5/5 21:21
Well I'm in the USA, so I'm not sure about legalities. I wouldn't think it would be a problem. However, I know it is carb'ed. It's got a nice sized 4-barrel on it which I considered snagging.
Posted on: 2010/5/6 1:39
