horn switch from steering wheel
From Sydney
hey gents
im trying to put a aftermarket wheel on but m having trouble fguring out which wire activates the relay swtch.im assuming its the brass thing that makes contact with the boss kit the black wire that comes of that, is that where connect my relay to?
im also using a 5 pin relay
87- to my horn
30- constant power, just gonna use igniton power
85- ground
86- switch, this wire is where i dont know where to hook up to
any help appreciated
dose ths sound riht
Posted on: 2012/3/12 10:08
Re: horn switch from steering wheel
From Sydney.au
from memory the horn wire is just a negative trigger, so when the wire is grounded, (eg to some part of the chassis ground) the horn should go. i have not the need for a horn relay, unless i put bigger horns in..? the horn relay you would want to put between the battery and the horn, if you were to use it.. also a horn you might need when the cars ignition is off, so the power should go direct to the battery via a fuse.
Posted on: 2012/3/12 15:03
yap it is correct. though the ignition on or off the horn should work.
and the other thing is we use relay for only double horn. for a single horn it is not require to use relay.
Posted on: 2012/3/12 17:49
From Sydney
Not sure if this is true by by law can you put your horn button on the dash or somewhere else other than your wheel?
Posted on: 2012/3/14 10:35
