supra gearbox
Hey all,
Im just after some info on putting a supra 5 speed into 1200. How do they fit? Use the standard shifter hole etc.
Also which boxes are used I seen theres w50, w55, w58 and so on.
Thanks in advance
Posted on: 2014/3/28 23:14
Re: supra gearbox
From Adelaide
Posted on: 2014/3/29 0:59
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: supra gearbox
From Townsville, Qld
Ill be doing it with an a series auto bell housing and adaptor ring I've yet to draw up. There's a 200mm Toyota clutch disk that would suit( from a Malaysian ute or town ace I think) that would perhaps save on custom clutches having to be made up. Tat way you just Ave to surface your flywheel to take a larger pressure plate to suit.
Posted on: 2014/3/29 6:28
Re: supra gearbox
From Adelaide
I remember chatting about this with you before. I still have the supra box on the floor of the shed next to the a series box but no luck. Maybe some beer will help them get the deed done That project's very much on the back burner for me.
Posted on: 2014/3/29 7:12
Re: supra gearbox
I have two :p granted they came out of a later celica or celica supra
Posted on: 2014/3/30 0:40
Re: supra gearbox
Uni is proving useful already because I'm learning about solid works which will make designing it a bit easier
Posted on: 2014/3/30 0:42
