WTB a15 carb (original if possible not ebay clone)
From Sydney, NSW
Hi all just wondering if anyone has an a15 stock carb not an eBay one but an original if possible.
I'm based in Sydney but happy to pay post
Posted on: 2017/1/23 13:31
Re: WTB a15 carb (original if possible not ebay clone)
From Las Vegas USA
I've got but being in the USA the shipping maybe steep.
Tom
Posted on: 2017/1/24 5:43
Shipping from USA to AUS is $76 USPS Priority flat rate Medium box
the carburetor I think will fit if the air cleaner stud is unscrewed from the carburetor
Posted on: 2017/1/24 6:28
From Sydney, NSW
I usually go through a forwarder with the US if you know the dimensions and weight I can get a quote :)
Posted on: 2017/1/24 8:59
Can't you just use an a12 carb
Posted on: 2017/1/25 7:25
From Sydney, NSW
How would I know if this is a15?
Posted on: 2017/1/28 6:40
A15 carb is bigger than A12 carb (same size on the outside, but larger throats)
A12 AUS: DCG-306, 20/26mm venturis
A15 AUS: DCF-306, 21/27mm venturis
The DCF has vacuum secondaries and a replaceable sight glass
A14 carb is largest version, as only low-RPM A15 (5600 RPM) was used in AUS
Posted on: 2017/1/28 6:55
From Sydney, NSW
Thanks dd I'll get the guy to check
Posted on: 2017/1/28 7:04
USA A15 uses:
* DCH-306 23/27mm venturis
* DCR-306 21/27mm venturis, vacuum secondaries, replaceable sight glass + vent system
The important thing is to get the airflow. I'd use an A14 carburetor or A15. Make sure the venturis are large -- look down the throats and you can see the numbers (even when fully assembled)
jpg  Hitachi venturi sizes.jpg (97.42 KB)
174_588c46b8974cb.jpg 800X590 px
Posted on: 2017/1/28 7:17
From Kelmscott Western Australia
Had A12 carby on a A15 makes no diffrence runs mint no worries
Posted on: 2017/1/28 12:14
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
