(1) 2 3 4 ... 8 »
A15 twin weber wont rev
From Bendigo, Victoria, Australia.
I though i would thow it open to everyone out there:
i recently started my A15 which is in my project ute and found it didn't want to rev.
it has:
tuned twin weber DCOE carbs
11.5:1 compression
cam, springs
JTS head
other stuff etc, but most importantly it has:
HEC 715 Bosch coil
NGK BP5ES plugs
new high tension leads
Datrats modified bluebird distributor
now. what i have done is taken out the ballast resistor, so that the coil runs on 12V (as it is meant to), i have wired up the distributor correctly (pink to positive...) i have the leads on the right plugs and on the right spot on the dizzy.
so i started my engine, and it idled fine. lumpy as expected, but fine.
let it warm up and went to give it a few revs and it started to die. sounded like the noise a 2stroke makes when you start it on old fuel (like its not firing...)
it has fresh fuel
it has enough fuel
there are no air leaks
started fine without chokes.
the only thing i can think of is that the coil isnt recieving 12V as it was supposed to. old wiring/dirity connections have dropped it to 10V.
could this be the reason my engine is useless (it cant rev) past 2000rpm?
anyone help me please. my mechanic couldnt so im gonna do it myself, #### the useless bastard, to him my ute is just a pile of scrap.
Posted on: 2007/3/6 19:31
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: A15 twin weber wont rev
From Malaysia
1.) Check petrol filter
2.) Check fuel pump
3.) Distributor contact terminals ( below cap )
4.) Rotor arm
5.) Battery & alternator
errmm..thats all i can think of
Posted on: 2007/3/6 20:05
From adelaide
not fouling plugs? Does it sound like its running on all 4clyls? Have you had it running properally before or did you just buy it? Should be good once its sorted
Posted on: 2007/3/6 20:13
1200 restoration project moving slower than it actually is
From Freo
check the accelerator pumps on the carbs..
thay can be an issue if the carbs have been sitting, and the jets are small..
Posted on: 2007/3/6 20:55
From Taupo New Zealand
have you checked the ignition timing?
Posted on: 2007/3/6 21:24
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Adelaide
I gather you have had to re-install the cam?
Check the cam to crank timing
Posted on: 2007/3/6 21:26
Nissanman - just trying to help...
From Newscastle, Australia
Oh cam another thing...make sure you have a fuel regulator on it. I set mine to 1.5 psi at most. If you are running a 4-6 psi pump its way too much youll need to knock it back.
This used to be my old engine and is sweet as a nut when running....
yeah those carbs have been sitting for a while the accelerator pumps could be an issue.Plus the jets could need cleaning. I dont know how they have been stored since I had them...
Posted on: 2007/3/6 22:12
Dont die wondering.....
Firstly:
petrol filter is new
Secondly:
fuel pump is new facet blue electronic one. running regulator (which is screwed all the way out, so its running at or < 2psi)
3rdly:
Battery is new and alternator is charging fine, it was the one off my old engine as the bosch one on there was a different one (plugs didnt match)
I will check the distributor contacts tomorrow when i get it home from the mechanics. altho they should be fine, dizzy is brand spankin'
Plugs are a possibilty. apparantly the BP5ES plugs arent renound to last a long time, even if they havent been used...
havent had the engine running properly before, as i said, it is my project and i just got it running the other day, only to find shes caught a bad case of unreliablulous enginous syndrome.
is running on all 4 though at idle, as revs pick up though it gets a bit shakey. thats why i think its the coil/weak spark. not fuel related.
Accelerator pumps could be an issue, infact the whole carbs could be the problem, freight and time could have screwed screws in/out a bit etc... will have a look at them when i get it home.
Ignition timing: havent checked it, i took it to the mechaniic primarily for them to put a timing light on it, but i dropped it off there, came back in a few days and they said it didnt even start for them... shoddy cunts that fiddle and blame it on others.... so they didnt even look at it.
anyway, the Zane said he put the base timing at 14deg BTDC
will check this myself though
if the cam was in the wrong spot, then i would have bent valves and the thing wouldnt have started at all...
Thanks for the tips guys. keep them coming
Posted on: 2007/3/6 23:22
Bob Dylan
From adelaide
yea plugs have done wierd things for me in the past, ive had four new bosh plugs die eg no spark at all even when cleaned/correct gap, changed plugs and ran perfect. Was only running approx one hour under no load, didnt get a refund either Maybe the coil is doing wierd things for you. Can you whip out a plug and lay it accross head and check spark quality, that might help!
Posted on: 2007/3/7 0:16
From Bunbury Western Australia
try using some cooler plugs like BP6ES or even BP7ES, sounds odd but every now and then my current A15 wont rev past 4000rpm, change the plugs and it's as good as new? never been able to figure out why this happens, but the cooler plugs definately last longer than the BP5ES plugs
Also check the voltage at the coil, and when you said you "removed the ballast resisitor" did you replace it with a piece of cable to join both ends of the resistor wires together or did you just leave both wires off and un-connected to anything?
I definately think it is spark related but perhaps to rule out fuel problems try giving the carbs a dose of carby clean through the fuel inlet hoses of both carbs and try starting it, it will run like crap with carby clean in the fuel but could help free up sticky pumps, floats etc.
Posted on: 2007/3/7 0:27
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
(1) 2 3 4 ... 8 »
