Browsing this Thread:
1 Anonymous Users
easy brake swap.. super easy just takes the whole day to swap |
Quite a regular
From pretoria, south africa
i got two 1400 struts and brakes left and right and as you can see there`r bigger and much better they`re like the size of sentra brakes.. but atleast i think they`re better gonna wear them in 2moro, i got a fright when putting the wheels back on cause they didnt turn then i realized the standard rims dont go around the calipers but i swaped back with front cause i had other rims that clear it nicely.. other wise a good swap
Posted on: 2010/8/15 20:14
Re: easy brake swap.. super easy just takes the whole day to swap |
Quite a regular
oh yea just forgot you`d also want to get the other strut things that came from under the crossmember otherwise the other link thing that came standard attaches,the holes line up its just the other one has a bigger gap so the 1200 one doesnt seal it too well so the split pin on the crown nut will eventualy rust, i just think water and stuff can get in it and i think another thing is the caster looked quite hectic but i drove it around a bit and it seemed to have came right.. they come from a 1400 bakkie if anyone was wondering, the bakkie obviously made a bit better for taking a bit of weight.. better brakes were obvious
Posted on: 2010/8/15 20:31
