Theoretically there is 'nothing' wrong with the tailshaft being on an angle (they are already on an angle due to the trans output shaft being ever so slightly different height than the diff yoke in 99% of cars out there anyway) AS LONG AS the two yokes are on 'parallel' angles.
Due to the way universal joints work, believe it or not, when the gearbox output shaft and diff pinion are rotating at a constant speed, the tailshft itself will be speeding up a fraction, slowing down, speeding up, slowing down, during every single revolution. As long as the gearbox output shaft and diff pinion are parallel (but not necessarily aligned) this all evens out (you also have to have each uni joint flange welded on in perfect alignment at each end of the tailshaft, it'll perform precisely how it is meant to and be (assuming it's balanced and not buckled) vibration free. But if you (hypothetically) altered the diff pinion angle a lot, and or the engine setback angle a lot, so those angles weren't parallel to one another, then it can and will vibrate (and obviously a degree or two won't be enough to be noticeable usually, but 10 or more might be, the more the difference, the more significant the vibration)
Having said all that, having the diff pinion and the tailshaft on an angle laterally (rather than just the usual slight horizontal) risks putting the tailshaft closer to the tunnel, esp if the rear leaves start to wind up with a lot of force (and naturally much higher output engines are why this diff would be put there in the first place) and so forth - it's basically just adding another variable which isn't optimal in there.
Although, as mentioned, the uni joints 'will' function properly when the output shaft and diff pinion angles are parallel - even if the tailshaft it on an angle, well this 'speeding up and slowing down' stuff becomes more severe (i.e. the difference between it's lowest and highest speeds in any one rotation gets higher and higher) the larger the angle. This in and of itself can eventually get to a point where it will be a vibration from the abrupt changes in tailshaft rpm. So it will be more problematic eventually, and will cause faster uni joint wear. If you absolutely had to do it on large angles then the 'real' answer would have to be to custom make CV joints (which as the name suggest have 'constant velocity' and the rpm of the intermediate shaft (the tail shaft in other words) doesn't speed up and slow down, it runs at constant/steady rpms in sync with the output shaft and diff pinion. For this and other reasons CV joints can handle greater angles (it's not just the vibration etc, the amount of metal around the flanges of a uni joint take up space and make it difficult to allow a severe angle without them hitting each other and jamming).
If you can at all possibly do it without costing a million in new custom axles, I'd personally aim for having the tailshaft parallel and straight when viewed from overhead.
Posted on: 2010/11/30 9:11
