Browsing this Thread:
1 Anonymous Users
1200/early 120Y Front Wheel Bearing part numbers |
Not too shy to talk
Hi all,
Just wanting confirmation on the front wheel bearing part numbers for the 1200 and the early 120Y (up to Oct '75).
The kits I can find for sale have a different part number for the inner bearing (30205, not 30305 as noted in the tech article). The outer bearing part number matches (30302)
Is it possible that there is a typo in the tech article and it should be 30205?
Cheers.
Posted on: 2019/3/26 5:28
Re: 1200/early 120Y Front Wheel Bearing part numbers |
Registered Users Contentmaster Usermaster
yes it's possible, looks like it is wrong. I will update it
Type 30305 62x25mm Type 30205 52x25mm (correct size for B110 & early B210)
Under the "Inner" section where is says Type 30305, I see that most of the bearings listed have 30205 in their number
Posted on: 2019/3/26 5:47
Not too shy to talk
Thanks for the confirmation. Like you, I also noticed that a few of the aftermarket bearings had the 30205 number, and that the 30305 is a larger bearing (62 OD.)
Appreciate your quick response as I'm changing the front bearings in my 1200 Coupe on Friday.
Cheers.
Posted on: 2019/3/26 5:56
