Re: datsun 1200 sedan standard front suspention problem
From Las Vegas USA
When I worked at the Toyota Dearship many years ago we would do a strut pull. There is a tool that bolts to the hub via lug nuts and then a hydraulic ram clamps to the strut. This bends the strut outward at the bottom - negative camber. also you can notch the stud holes in the strut tower. It sounds like something is worn - check all the suspension componets you either have way to much toe in or positive camber.
Tom
Posted on: 2004/1/28 1:45
Subject Poster Date
     datsun 1200 sedan standard front suspention problem 1200GXman 2004/1/26 6:55
       Re: datsun 1200 sedan standard front suspention problem dattodevil 2004/1/26 7:07
         Re: datsun 1200 sedan standard front suspention problem Dodgeman 2004/1/26 11:43
       Re: datsun 1200 sedan standard front suspention problem dattodude 2004/1/26 13:08
         Re: datsun 1200 sedan standard front suspention problem 1200GXman 2004/1/27 6:42
           Re: datsun 1200 sedan standard front suspention problem ddgonzal 2004/1/27 7:08
             Re: datsun 1200 sedan standard front suspention problem BOOF 2004/1/27 11:03
               Re: datsun 1200 sedan standard front suspention problem Rallytwit 2004/1/28 1:45
