Browsing this Thread:
1 Anonymous Users
Re: attn carby gurus |
From Wanganui, New Zealand
2" is too small for anything other than a standard A15. 2 1/4" is fine for good midrange power but for a full out 8000rpm A15 2 1/2 is best. We actually used 2 1/2 on our best 1300 Rally motor because it was working between 5500 - 8500rpm. Regarding the carbs, I would tend to stick with 40mm, unless again it is a full house 8000rpm monster. It will definately help the torque with the smaller carbs. In regard to Dynos in the NI I can't actually recommend any in particular, Stirlingmac may be able to help there. My only comment would be to try to find someone that uses a "sniffer" type exhaust gas analyser to check fuel mixture rather than O2 sensors. Hope this helps.
Posted on: 2004/1/30 17:35
