Re: Stud Pattern Adapters
From Sydney, Australia
It's so hard, that I've never seen it done. It might work for mazdas, because their hubs use bolts not nuts. But the offsets will change some 10 mm at least. This is 20mm to the track, this changes the forces put on the hub and bearings, which can only adversely affect their load capacity.
Spacers are not specifically illegal, but if a cop doesn't like the look of them then he'll defect you for them.
Unless you can get the hubs drilled out, "Let it go", I know these wheels are probably nice, but they are no good to you.
Posted on: 2004/3/29 5:44
Subject Poster Date
     Stud Pattern Adapters Razor 2004/3/28 23:54
       Re: Stud Pattern Adapters dattodude 2004/3/29 1:58
         Re: Stud Pattern Adapters Razor 2004/3/29 2:19
           Re: Stud Pattern Adapters Razor 2004/3/29 4:07
             Re: Stud Pattern Adapters dattodude 2004/3/29 5:44
               Re: Stud Pattern Adapters Razor 2004/3/29 5:52
                 Re: Stud Pattern Adapters L18_B110 2004/3/29 7:08
                   Re: Stud Pattern Adapters Razor 2004/3/29 11:48
                     Re: Stud Pattern Adapters Razor 2004/4/1 2:31
                       Re: Stud Pattern Adapters Razor 2004/4/1 22:56
                       Re: Stud Pattern Adapters DOG 2004/4/1 23:08
                         Re: Stud Pattern Adapters Razor 2004/4/1 23:15
                           Re: Stud Pattern Adapters DOG 2004/4/5 14:31
                             Re: Stud Pattern Adapters Razor 2004/4/5 23:01
                               Re: Stud Pattern Adapters DOG 2004/4/7 16:17
                                 Re: Stud Pattern Adapters kegs 2004/4/7 16:25
