Re: do I need to retighten the head bolts after running in the head gasket
Quite a regular
From Perth Oz
Yep cheers Dodgeman,
Lubed bolts and cleaned it all first time and installed it COLD - just like the article, common sense, and both of the dato manuals direct.
guess I'll back each bolt off half a turn - would'nt want it too loose as it may shift the join between the head and block
FYI the wrapper doesnt say if retensioning is required that's why I asked........
Posted on: 2004/4/13 13:30
Subject Poster Date
     do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/12 6:13
       Re: do I need to retighten the head bolts after running in the head gasket ddgonzal 2004/4/12 6:34
         Re: do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/12 6:47
           Re: do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/12 10:34
             Re: do I need to retighten the head bolts after running in the head gasket Dodgeman 2004/4/12 11:54
               Re: do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/13 13:30
                 Re: do I need to retighten the head bolts after running in the head gasket datsik 2004/4/13 14:52
                   Re: do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/13 16:09
                     Re: do I need to retighten the head bolts after running in the head gasket ddgonzal 2004/4/14 1:31
                       Re: do I need to retighten the head bolts after running in the head gasket feral 2004/4/14 13:22
                       Re: do I need to retighten the head bolts after running in the head gasket datsik 2004/4/14 14:10
                       Re: do I need to retighten the head bolts after running in the head gasket datsik 2004/4/14 14:28
                         Re: do I need to retighten the head bolts after running in the head gasket Dodgeman 2004/4/14 14:47
                           Re: do I need to retighten the head bolts after running in the head gasket datsik 2004/4/14 16:55
                             Re: do I need to retighten the head bolts after running in the head gasket ddgonzal 2004/4/14 18:30
                               Re: do I need to retighten the head bolts after running in the head gasket A14force 2004/4/15 9:49
                                 Re: do I need to retighten the head bolts after running in the head gasket dato1000ute 2004/4/15 17:11
                                   Re: do I need to retighten the head bolts after running in the head gasket feral 2004/4/16 0:11
