Re: A15tt problems analysis
stuff the coil. I have seen a12's boosted over 30psi and still running points.
I would look at your fuel pump first.
If it is ignition all it will be is it needs more advancement. But more advancement will make the car harder to start. If you wanna see if it needs more advancement start the car and then dial alittle more advance in and then see how it goes. But dont waste time on changing the coil because unless your one is dead I can tell you from experience that it will be ok.
Posted on: 2004/4/27 12:57
Subject Poster Date
     A15tt problems analysis 1200rallycar 2004/4/27 12:30
       Re: A15tt problems analysis Anonymous 2004/4/27 12:34
         Re: A15tt problems analysis dattodevil 2004/4/27 12:37
           Re: A15tt problems analysis 1200rallycar 2004/4/27 12:40
           Re: A15tt problems analysis Anonymous 2004/4/27 12:40
             Re: A15tt problems analysis dattodevil 2004/4/27 12:44
               Re: A15tt problems analysis Anonymous 2004/4/27 12:46
                 Re: A15tt problems analysis 1200rallycar 2004/4/27 12:48
                   Re: A15tt problems analysis dattodevil 2004/4/27 12:50
                     Re: A15tt problems analysis phunkdoktaspok 2004/4/27 12:57
                       Re: A15tt problems analysis dattodevil 2004/4/27 13:03
                         Re: A15tt problems analysis phunkdoktaspok 2004/4/27 13:07
                       Re: A15tt problems analysis 1200rallycar 2004/4/27 13:04
                         Re: A15tt problems analysis dattodevil 2004/4/27 13:07
                           Re: A15tt problems analysis Anonymous 2004/4/27 13:14
                           Re: A15tt problems analysis MadTimo 2004/4/27 13:16
                             Re: A15tt problems analysis 1200rallycar 2004/4/27 13:20
                               Re: A15tt problems analysis MadTimo 2004/4/27 13:26
                                 Re: A15tt problems analysis 1200rallycar 2004/4/27 13:29
                                   Re: A15tt problems analysis L18_B110 2004/4/27 22:39
                                     Re: A15tt problems analysis go_the_datto 2004/4/28 0:34
                                       Re: A15tt problems analysis ddgonzal 2004/4/28 3:49
                             Re: A15tt problems analysis dattodevil 2004/4/27 13:21
                   Re: A15tt problems analysis Anonymous 2004/4/27 12:54
                     Re: A15tt problems analysis dattodevil 2004/4/27 12:57
