Re: blow thru or draw thru
From Christchurch NZ
Dude, I will be buildimg one of these after my blown car is completed. The easyest way to force feed an "A" is a drawthrough turbo with an SU or stromberg type sidedraft. If you monkey with the needle and get the mixture right for the engine while it is still NA, it should provide the right mixture whilst drawing through. If big boost starts to cause detonation, A water injection set up can be built cheap as chips.
That is the cheapest way to make it haul ass. if youcan do the work yourself . it should be doable for less than the price of twin sidedraft. Leave Injection for poeple with too much money.
Posted on: 2004/6/3 9:32
Forced Induction!
Subject Poster Date
     blow thru or draw thru ralliarton18s 2004/6/2 5:55
       Re: blow thru or draw thru olboy 2004/6/2 6:04
         Re: blow thru or draw thru ralliarton18s 2004/6/2 6:11
           Re: blow thru or draw thru pro-240c 2004/6/2 7:47
             Re: blow thru or draw thru who_your_datty_1200 2004/6/2 7:53
               Re: blow thru or draw thru NoPsi 2004/6/3 2:14
                 Re: blow thru or draw thru phunkdoktaspok 2004/6/3 2:39
                   Re: blow thru or draw thru pro-240c 2004/6/3 6:39
                     Re: blow thru or draw thru L18_B110 2004/6/3 7:19
                       Re: blow thru or draw thru A14force 2004/6/3 9:32
                         Re: blow thru or draw thru roddat 2004/6/3 10:58
                           Re: blow thru or draw thru A14force 2004/6/3 11:03
                             Re: blow thru or draw thru Anonymous 2004/6/3 11:24
                             Re: blow thru or draw thru Ash 2004/6/3 11:38
                               Re: blow thru or draw thru A14force 2004/6/3 11:42
                                 Re: blow thru or draw thru roddat 2004/6/3 11:57
                                   Re: blow thru or draw thru ralliarton18s 2004/6/3 18:03
                                     Re: blow thru or draw thru Dodgeman 2004/6/3 21:58
                                       Re: blow thru or draw thru ralliarton18s 2004/6/3 22:09
                                         Re: blow thru or draw thru A14force 2004/6/3 22:19
                                           Re: blow thru or draw thru ralliarton18s 2004/6/3 22:32
                                             Re: blow thru or draw thru A14force 2004/6/3 22:36
                                               Re: blow thru or draw thru ralliarton18s 2004/6/3 22:42
                                                 Re: blow thru or draw thru A14force 2004/6/3 22:53
                                                   Re: blow thru or draw thru Ash 2004/6/3 23:29
                                                     Re: blow thru or draw thru NoPsi 2004/6/4 0:51
                                                       Re: blow thru or draw thru phunkdoktaspok 2004/6/4 4:02
                                                 Re: blow thru or draw thru ddgonzal 2004/6/4 4:08
                                                   Re: blow thru or draw thru ralliarton18s 2004/6/4 4:19
                                                     Re: blow thru or draw thru kawazuki 2007/3/8 16:19
                                                       Re: blow thru or draw thru pager 2007/3/8 18:07
                       Re: blow thru or draw thru pro-240c 2004/6/4 1:40
