Browsing this Thread:
1 Anonymous Users
Dimming Headlight |
From Brisbane
i got this problem with my car... everything dims when the engine is idling, above 1,000 RPM everything goes bright again. Even the indicator when its on and you're just idling its very slow or sometimes just stops blinking its just on. I got a amp gauge and its reading below 0 and it reads above 0 when car is moving or above 1,000 rpm.
I checked fuses, fusible link and alternator is charging 13.5V battery is quite new few months old and tested it for 12 - 12.5 V I opened the alternator to check brush and probably got 8mm - 10mm from the limit. Cleaned the inside as well and still the same. Check the fan belt delfection, timing, change spark plugs, points, and rotor button.
do you think its just the alternator? I heard it can be the ground?
Posted on: 2004/7/20 4:32
