Re: Filling the Radiator - Water?
From Adelaide, Australia
Hi there, take a trip down to your local auto shop, you can buy coolant in two forms pre-mixed or undiluted, I recommend buying a good quality undiluted bottle, most 500ml bottles will make 10 litres, you will only need 4 litres i think so its good for 2 flushes, clean your cooling system first, I always pull the heater hose off, put a hose in one end and have the other end drain out on the ground or in a bucket to flush the heater because these can get quite blocked. Replace any soft or cracked hoses as these can leak or if too soft can collapse causing overheating.
Posted on: 2004/8/2 11:35
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Subject Poster Date
     Filling the Radiator - Water? AlphDoti 2004/8/2 11:19
       Re: Filling the Radiator - Water? WhiteSedan 2004/8/2 11:35
         Re: Filling the Radiator - Water? WhiteSedan 2004/8/2 11:36
           Re: Filling the Radiator - Water? ddgonzal 2004/8/2 16:49
       Re: Filling the Radiator - Water? dattodevil 2004/8/2 11:35
