Re: Which engine should i use??
From Perth W.A
well in my experiance of putting in a newer A series in place of the old one in my 74 120Y all i needed to do was change the intake side engine mount, and it bolted up fine. all wiring reached and was not tight and everything went on okay. i put in an A14 and had no troubles i did the conversion in a day. that included putting on the booster and other items from a late 120Y. you make things a lot harder than they seem most of the time dodgeman i like your ways of looking at all things that could go wrong but you can scare people away from doing things with your exasperating indepth views. no need to make things harder than they are.....
Posted on: 2004/8/10 2:19
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Subject Poster Date
     Which engine should i use?? RazoR_PT 2004/8/9 11:07
       Re: Which engine should i use?? Dodgeman 2004/8/9 11:47
         Re: Which engine should i use?? RazoR_PT 2004/8/9 14:30
           Re: Which engine should i use?? Dodgeman 2004/8/9 22:20
             Re: Which engine should i use?? Team_Dat 2004/8/10 2:19
               Re: Which engine should i use?? ddgonzal 2004/8/10 2:42
                 Re: Which engine should i use?? RazoR_PT 2004/8/10 9:54
                   Re: Which engine should i use?? RazoR_PT 2004/8/10 16:56
                     Re: Which engine should i use?? ddgonzal 2004/8/11 5:12
                       Re: Which engine should i use?? RazoR_PT 2004/8/11 8:46
                         Re: Which engine should i use?? ddgonzal 2004/8/11 9:04
                           Re: Which engine should i use?? RazoR_PT 2004/8/11 10:48
                             Re: Which engine should i use?? anb008 2004/8/11 14:00
                               Re: Which engine should i use?? RazoR_PT 2004/8/11 17:10
                                 Re: Which engine should i use?? A-14 2004/8/11 19:30
                                   Re: Which engine should i use?? RazoR_PT 2004/8/12 10:24
                                     Re: Which engine should i use?? woodydat 2004/8/12 10:32
                                       Re: Which engine should i use?? RazoR_PT 2004/8/12 11:40
       Re: Which engine should i use?? My_lil_beast 2004/8/11 13:50
