Re: Worn Outer/InnerTie Rod End
easiest way is to check them while the car is on the ground/over pit, get some one to wobble the steering wheel left to right and hold each tie rod joint in between your fingers, you should feel no play in these joints......( i have been a suspension tech for several years!) good luck!
Posted on: 2004/8/24 11:57
Subject Poster Date
     Worn Outer/InnerTie Rod End Razor 2004/8/23 23:56
       Re: Worn Outer/InnerTie Rod End NoPsi 2004/8/24 0:16
         Re: Worn Outer/InnerTie Rod End pavlos1200 2004/8/24 11:57
           Re: Worn Outer/InnerTie Rod End Razor 2004/8/24 21:49
