Re: My rear tyres are rubbing.What can I do?
From South Africa, Bloemfontein
Just an update.
I inspected my diff last night.
Through inspection I saw that the whole diff in the back cannot be missaligned by accident.
on the sides , where the shock absorber is bolted to the diff, and where the U joints are put over the diff, I saw there is brackets that are whelded onto the diff so that the U joints are put over them and bolted tight.
The U bolts fits nicely into grooves on these brackets.
So there is no way it can be off centre except if it came from the factory that way.
I think I am just going to test my rim to see if it does'nt have a different offset.
If this is fine, then there is only one solution.
I must build out my wheel arches.
Just wanted to let you guys know.
Posted on: 2004/10/8 9:00
1977 Datsun 1200GX
Subject Poster Date
     My rear tyres are rubbing.What can I do? 1200GXman 2004/10/5 11:34
       Re: My rear tyres are rubbing.What can I do? TUFDAT 2004/10/5 11:41
       Re: My rear tyres are rubbing.What can I do? dattodude 2004/10/5 12:17
         Re: My rear tyres are rubbing.What can I do? L18_B110 2004/10/5 12:28
           Re: My rear tyres are rubbing.What can I do? 1200GXman 2004/10/5 13:26
             Re: My rear tyres are rubbing.What can I do? ang94541 2004/10/8 18:21
             Re: My rear tyres are rubbing.What can I do? dattodude 2004/10/5 13:43
               Re: My rear tyres are rubbing.What can I do? L18_B110 2004/10/5 23:53
                 Re: My rear tyres are rubbing.What can I do? 1200GXman 2004/10/6 6:33
                   Re: My rear tyres are rubbing.What can I do? dattodude 2004/10/6 6:42
       Re: My rear tyres are rubbing.What can I do? ddgonzal 2004/10/6 7:37
         Re: My rear tyres are rubbing.What can I do? 1200GXman 2004/10/6 7:44
           Re: My rear tyres are rubbing.What can I do? 1200GXman 2004/10/8 9:00
             Re: My rear tyres are rubbing.What can I do? sidedraught 2004/10/8 11:53
               Re: My rear tyres are rubbing.What can I do? Dodgeman 2004/10/8 13:48
                 Re: My rear tyres are rubbing.What can I do? 1200GXman 2004/10/8 13:59
       Re: My rear tyres are rubbing.What can I do? ddgonzal 2004/10/9 17:39
         Re: My rear tyres are rubbing.What can I do? selfwedge 2005/1/3 6:28
           Re: My rear tyres are rubbing.What can I do? ddgonzal 2005/1/17 17:14
