Offset grind on CA18 crank
From Bris-Vegas
It looks like I've done a Big end on my CA18, so i'm toying with the idea (along with balancing etc.) of doing an offset grind on the crank to increase displacement..........
Has anyone here done this - do you know if there is a standard piston / conrod available that will slot straight in to save machining the piston?
Posted on: 2004/12/28 21:22
Subject Poster Date
     Offset grind on CA18 crank Coops 2004/12/28 21:22
       Re: Offset grind on CA18 crank feral 2004/12/28 22:39
         Re: Offset grind on CA18 crank Coops 2004/12/28 23:47
           Re: Offset grind on CA18 crank feral 2004/12/29 11:40
