Browsing this Thread:
1 Anonymous Users
No Spark In Datsun Pulsar.. |
Hi,
I have just changed the motor in my N10 Datsun Pulsar and I am getting no spark from the coil.
By using a teat lamp on the + and - on the coil, I am getting power to them. But as I crank the engine, no spark is coming from the coil. I have changed coil/plugs/leads/points/condenser/Distributor and I even took my kill switch out to see if that was causing the problem.
I am assuming the wiring is correct as I am getting power to the coil, but I could be wrong.
I am guessing that the white ceramic thingy next to the coil is the ballast resistor?? Is this true, if so, Can this be causing the problem.
I strongly appreciate your help.. :)
Posted on: 2005/2/9 15:24
