910 struts on 1200 lowering ratio
From Christchurch. NZ
I thought I would post that with 910 struts on 310 suspension fitted to a 1200, the ratio between the spring height and height at the wheel is 0.85:1, that means if you lower the spring 85mm, the ride height is reduced 100mm
Posted on: 2005/3/1 10:30
Subject Poster Date
     910 struts on 1200 lowering ratio dattodevil 2005/3/1 10:30
       Re: 910 struts on 1200 lowering ratio NZ_datto 2005/3/1 19:44
         Re: 910 struts on 1200 lowering ratio dattodevil 2005/3/2 9:20
