Re: help ive stuffed it!
From Perth WA
ok what i did was get each piston right on compression stroke tdc and check where the rotor was facing in the dizzy, to make sure facing the right lead. then i adjusted all the tappets like that. and it fired straight up. I think it was way out how i had it, baqckfiring and all.
if u remember i had to do all this becuase i cooked my motor and warped my head....
I can attest dodgemans way of cleaning the water/oil sludge "choc-milk" with 1/3 kero and oil worked a treat. it really dislodges the sludge when it gets nice and hot too after fast idling for 10-15 mins. better than 3 or 4 oilchanges and filters for sure!
the extra compression, shaved 60 thou or 1.5 mm makes it a lot harder to turn the motor by hand, but not much more if any acceleration. probably a touch more torque.
Im thinking of carbs cam and headers now, whats the best value combo for an A14 in a KB10, keeping in mind clearance under bonnet and engine bay???
Posted on: 2005/3/7 12:57
Subject Poster Date
     help ive stuffed it! 1000Coupe 2005/3/4 5:33
       Re: help ive stuffed it! nicholas 2005/3/4 6:12
         Re: help ive stuffed it! 1000Coupe 2005/3/4 7:43
           Re: help ive stuffed it! L18_B110 2005/3/4 8:46
             Re: help ive stuffed it! 1000Coupe 2005/3/4 9:10
               Re: help ive stuffed it! L18_B110 2005/3/4 9:19
                 Re: help ive stuffed it! Dodgeman 2005/3/4 12:59
                   Re: help ive stuffed it! 1000Coupe 2005/3/7 12:57
                     Re: help ive stuffed it! Dodgeman 2005/3/7 22:13
                       Re: help ive stuffed it! dattodevil 2005/4/5 11:17
                         Re: help ive stuffed it! datrat_dave 2005/4/5 14:11
                           Re: help ive stuffed it! Dodgeman 2005/4/5 14:37
                             Re: help ive stuffed it! dattodevil 2005/4/5 21:25
                               Re: help ive stuffed it! Rogue 2005/4/6 0:28
