Another Overheating Problem
From Brisbane
Hi
My car is running really hot, 60 - 70kph my temp gauge shows over 3/4 above that speed the temp gauge goes nearly on "H" top of the hot gauge
So far I checked my timing, idle, air/fuel mixture, timing belt, new thermostat with 3mm hole, swap my radiator to 323 one. I checked the radiator 1st before installing it and seems pretty good flowing really well and fins look great.
Flush the old coolant and new coolant in 323 radiator then run for few minutes for air pockets.
I can't hear any loud bearing noise for my waterpump or no leakage coming from the pump.
I checked my compression
Cylinder 1 = 172
Cylinder 3 = 170
Cylinder 4 = 165
Cylinder 2 = 168
recently I noticed blue-ish smoke on start up so probably need valve seal or rings...
No milky stuff in the radiator so far, no leaking hoses
Any suggestions or ideas?
Cheers
Posted on: 2005/3/15 1:49
Subject Poster Date
     Another Overheating Problem Razor 2005/3/15 1:49
       Re: Another Overheating Problem Freak 2005/3/15 2:42
       Re: Another Overheating Problem ca18det_man 2005/3/15 2:53
         Re: Another Overheating Problem Razor 2005/3/15 3:33
           Re: Another Overheating Problem 1956 2005/3/15 4:32
             Re: Another Overheating Problem COUP1200 2005/3/15 5:02
               Re: Another Overheating Problem datrat_dave 2005/3/15 7:13
                 Re: Another Overheating Problem Razor 2005/3/15 22:05
                   Re: Another Overheating Problem COUP1200 2005/3/15 22:25
                     Re: Another Overheating Problem datrat_dave 2005/3/16 5:49
