Re: siliva radiator installing woes
From Sydney Australia
Pull all the grill off and cut a big hole in the radiator support should fit perfectly dont cut the lugs off the radiator drill some holes in the chassie x-member to locate the radiator properly. Once you pull the radiator out you can clearly see what has to be done.
Posted on: 2005/3/19 4:23
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Subject Poster Date
     siliva radiator installing woes greddydattocoupe 2005/3/19 3:21
       Re: siliva radiator installing woes LAGWAGON 2005/3/19 3:24
         Re: siliva radiator installing woes greddydattocoupe 2005/3/19 3:28
           Re: siliva radiator installing woes LAGWAGON 2005/3/19 3:32
             Re: siliva radiator installing woes 731200 2005/3/19 4:23
               Re: siliva radiator installing woes B120dat 2005/3/19 9:44
