A SERIES TWIN CAM A REAL POSSIBILITY!
From Millgrove Vic OZ
While you were all at Datnats having fun,
the feral gnomes found a twin cam head that is a bolt up to the A series block. (See photo album or DATRATS.COM.AU
This head is a bolt up and can be adapted with a bit of TIG work, machining and fabrication.
The main problems are in order closing of the pushrod holes, moving some water galleries and modifying the cam drive.
I intend to keep on with this in spare time as I think its reasonably easily do-able.
Why bother? Because I can
Posted on: 2005/3/28 10:02
Cheers Feral
Subject Poster Date
     A SERIES TWIN CAM A REAL POSSIBILITY! feral 2005/3/28 10:02
       Re: A SERIES TWIN CAM A REAL POSSIBILITY! ca18det_man 2005/3/28 12:24
         Re: A SERIES TWIN CAM A REAL POSSIBILITY! D 2005/3/28 12:38
           Re: A SERIES TWIN CAM A REAL POSSIBILITY! feral 2005/3/28 13:42
             Re: A SERIES TWIN CAM A REAL POSSIBILITY! D 2005/3/28 14:19
               Re: A SERIES TWIN CAM A REAL POSSIBILITY! feral 2005/3/29 0:34
                 Re: A SERIES TWIN CAM A REAL POSSIBILITY! L18_B110 2005/3/29 0:48
                   Re: A SERIES TWIN CAM A REAL POSSIBILITY! feral 2005/3/29 0:54
                     Re: A SERIES TWIN CAM A REAL POSSIBILITY! Grunterhunter 2005/3/29 2:50
                       Re: A SERIES TWIN CAM A REAL POSSIBILITY! D 2005/3/29 4:35
                         Re: A SERIES TWIN CAM A REAL POSSIBILITY! Grunterhunter 2005/3/29 7:38
       Re: A SERIES TWIN CAM A REAL POSSIBILITY! matbighat 2005/3/29 9:08
         Re: A SERIES TWIN CAM A REAL POSSIBILITY! D 2005/3/29 10:40
         Re: A SERIES TWIN CAM A REAL POSSIBILITY! pro240c 2005/3/29 10:53
         Re: A SERIES TWIN CAM A REAL POSSIBILITY! Dodgeman 2005/3/29 11:51
           Re: A SERIES TWIN CAM A REAL POSSIBILITY! kegs 2005/3/29 13:26
             Re: A SERIES TWIN CAM A REAL POSSIBILITY! matbighat 2005/3/29 20:10
               Re: A SERIES TWIN CAM A REAL POSSIBILITY! Rallytwit 2005/3/29 22:04
                 Re: A SERIES TWIN CAM A REAL POSSIBILITY! Anonymous 2005/3/30 0:43
                   Re: A SERIES TWIN CAM A REAL POSSIBILITY! D 2005/3/30 1:34
                     Re: A SERIES TWIN CAM A REAL POSSIBILITY! Niscoupe 2005/3/30 20:57
                       Re: A SERIES TWIN CAM A REAL POSSIBILITY! matbighat 2006/1/12 7:38
