Re: Roller lifters
You need some way to stop the roller lifters from rotating in the lifter bore, usually this is done by way of a bar / plate with a pivot on each end joining 2 lifters together, to use this system in the A series you would need to either extend the lifter size beyond the bottom of the lifter bore or put a slot in the sides of the lifter bores.
There may be other ways to do it though.
Posted on: 2005/4/3 13:22
Subject Poster Date
     Roller lifters Meat_rack 2005/4/3 11:01
       Re: Roller lifters MLS 2005/4/3 11:54
         Re: Roller lifters Meat_rack 2005/4/3 12:03
           Re: Roller lifters boofhead 2005/4/3 12:06
           Re: Roller lifters 2332owner 2005/4/3 12:10
             Re: Roller lifters dattoman_1000 2005/4/3 12:46
               Re: Roller lifters Meat_rack 2005/4/3 13:16
                 Re: Roller lifters MLS 2005/4/3 13:22
                   Re: Roller lifters Meat_rack 2005/4/3 13:31
